Guys I dont know about you but i have had it with 1.0.4.6, it is not fit for beta. I ahev about 10 devices set in Static DCHP, but none seem to get working unless you leave it for approx 20 minutes. then finally the IP is obtained.
My RV220W is part of a Double natted LAN, and worked fine with 1.0.3.5 but every now and then even the WAN wont work with it either set to DHCP or Static IP.
I now have reverted back to 1.0.3.5 as this is has now given me half of the problems that the new beta has.
Simon.
Regards Simon
