Dual Radio SSID names
Brian Bergin
Level 4
Level 4
For someone setting up a dual band WAP for the first time it's unclear if the SSIDs on Radio 1 and Radio 2 should be the same and let the device hash out which it will connect to or should they be different.  Regardless of which is the proper, it should be clearly noted in the setup wizard (as well as which Radio is 5G and which is 2.4G, which it currently does not do).
Xiao Han
Thanks Brian,
It's a good suggestion , we will try to add it in next firmware.
Xiao
