How to enable content filter for DistributionGroup
mads
I have enablet content filtering i default Policy with a newly created content filter called Blacklist_distributiongroup
The incoming content filter is configured with following rules
Blacklist_distributiongroup: if (rcot-to-group == allindomaingroup@domain.com) {drop(); }
But it doenst drop mail - it is send throug to recipient
What am i doing wrong ???
jsteer
Mads - i'd check that the message is :
a. is the address correct as it's comes through from the internet?
b. is the content filter active
c. what do you see in the mail_log when the message passes thru?
I'd suggest you use the trace option in the GUI to mimic a message to this address and see wha the output is.
The rcpt-to-group rule is using ldap to match up an address. Is your ldap connection setup?
Perhaps its worth changing the filter to be:
Blacklist_distributiongroup: if (rcpt-to == allindomaingroup@domain.com) {drop(); }
Good luck
jason
jsteer
Good luck
jason
Hi Jason
Question a,b and c was allready checked -
I Changed the content rule to
Blacklist_distributiongroup: if (rcpt-to == ^allin) {drop(); }
Now it works
Mads
