UK320 Feedback: remote management
ADAM CRISP
Level 4
Level 4
It is not clear that remote management uses https.
Also, outr test unit appears to not accept user authentication on the WAN side, even thought logons are sucsessful on the LAN side. (this used to work but has stopped)
nalbert
Level 4
Level 4
- Remote managent does use https.
- The UC320 blocks all registrations on the WAN side. Only Accepts registrations from the LAN side. WAN registration feature will be built into it in the future to accomodate teleworkers.
You use http on the LAN side, but when enabling WAN side management, there are no big red letters telling you to use https for remote management, and that http is disabled - I'm just making the point a configuration note would be helpful to users.
thanks
Adam
