em 12-30-2011 12:26 PM
Para atualizar o software do ASR 5000, é necessário seguir o passo a passo descrito neste documento:
•3. Verifique a versão do novo arquivo:
#show ver /flash/production.39936.asr5000.bin
Reading /flash/production.39936.asr5000.bin... done
OPERATIONAL_IMAGE Version : 12.0 (39936)
OPERATIONAL_IMAGE Description : ASR5000 Production Build <39936>
OPERATIONAL_IMAGE Date : Wednesday September 21 03:14:12 GMT 2011
OPERATIONAL_IMAGE Size : 170490368
OPERATIONAL_IMAGE Flags : None
OPERATIONAL_IMAGE Platform : ASR5000
#show boot
Monday September 26 23:35:20 CDT 2011
boot system priority 2 \
image /flash/production.39311.asr5000.bin \
config /flash/telcel_17_09_11.cfg
boot system priority 3 \
config /flash/porgp4_39311_28_08_2011.cfg
boot system priority 5 \
image /flash/production.38113.st40.bin \
config /flash/R9portales_26_08_2011.cfg
boot system priority 15 \
image /flash/production.36000.st40.bin \
config /flash/17Jun2011.cfg
Existem até 10 prioridades de boot configuradas.
Efetue o backup da configuração existente:
#save conf /flash/Telcel26092011.cfg -noconfirm –redundant
#filesystem synchronize all
Monday September 26 23:37:39 CDT 2011
3 to be updated on card 9
/flash/boot.sys
/flash/telcel_17_09_11.tar
0 to be updated (but are newer) on card 9
1 to be deleted on card 9
/flash/telcel-portales-test-0614.cfg
Are you sure? [Yes|No]: yes
Monday September 26 23:38:05 CDT 2011
Updating /flash/boot.sys
Updating /flash/production.39936.asr5000.bin
Updating /flash/telcel_17_09_11.tar
3 updated on card 9
/flash/boot.sys
1 deleted on card 9
/flash/telcel-portales-test-0614.cfgs
config
Monday September 26 23:35:41 CDT 2011
(config)# no boot system priority 15
config
Monday September 26 23:38:53 CDT 2011
(config)# boot system priority 1 image /flash/production.39936.asr5000.bin config /flash/Telcel26092011.cfg
Monday September 26 23:39:16 CDT 2011
(config)# end
# sho boot
Monday September 26 23:39:21 CDT 2011
boot system priority 1 \
image /flash/production.39936.asr5000.bin \
# filesystem synchronize all
Monday September 26 23:39:27 CDT 2011
1 to be updated on card 9
/flash/boot.sys
0 to be deleted on card 9
Monday September 26 23:39:31 CDT 2011
1 updated on card 9
/flash/boot.sys
0 deleted on card 9
Verifique o número atual de usuários conectados:
# show session progress
Monday September 26 23:45:47 CDT 2011
991259 In-progress calls
991259 In-progress active calls
0 In-progress dormant calls
0 In-progress always-on calls
63 In-progress calls @ ARRIVED state
0 In-progress calls @ CSCF-CALL-ARRIVED state
Para iniciar o bloqueio de novas chamadas:
# newcall policy ggsn-service all reject
Tuesday September 27 01:04:35 CDT 2011
Para desconectar os usuários conectados:
# clear subscribers all -noconfirm
Tuesday September 27 01:04:49 CDT 2011
Number of subscribers cleared: 942135
A desconexão de usuários levará um certo tempo até ser concluída. É possível acompanhar o andamento até que o contador chegue a zero:
[local]PORGP4# show session progress
Tuesday September 27 01:19:04 CDT 2011
23 In-progress calls
23 In-progress active calls
[# reload -noconfirm
Tuesday September 27 01:19:09 CDT 2011.
# show ver
Tuesday September 27 01:30:51 CDT 2011
Active Software:
Image Version: 12.0 (39936)
Image Description: Production_Build
Image Date: Tue Sep 20 22:18:03 EDT 2011
Boot Image: /flash/production.39936.asr5000.bin
Status das placas:
# show card table
Tuesday September 27 01:25:10 CDT 2011
Slot Card Type Oper State SPOF Attach
1: PSC None - - - -
2: PSC Packet Services Card 2 Active No 18 34
3: PSC None - - - -
4: PSC Packet Services Card 2 Active No 20 36
5: PSC None - - - -
6: PSC Packet Services Card 2 Active No - -
7: PSC None - - - -
8: SMC System Management Card Active No 24 25
9: SMC System Management Card Standby - - -
10: PSC Packet Services Card 2 Standby - - -
11: PSC None - - - -
12: PSC None - - - -
13: PSC Packet Services Card 2 Active No 29 -
14: PSC Packet Services Card 2 Active No 30 -
15: PSC None - - - -
16: PSC None - - - -
40: RCC Redundancy Crossbar Card Standby -
41: RCC Redundancy Crossbar Card Standby -
# show linecard table
Tuesday September 27 01:25:17 CDT 2011
Slot Card Type # Ports Oper State SPOF Attach
17: LC None - - - -
18: LC Quad 1000 Ethernet Line Card 4 Ports Standby - 2
19: LC None - - - -
20: LC Quad 1000 Ethernet Line Card 4 Ports Active No 4
21: LC None - - - -
22: LC None - - - -
23: LC None - - - -
24: SPIO Switch Processor I/O Card 4 Ports Active No 8
25: SPIO Switch Processor I/O Card 4 Ports Standby - 8
26: LC None - - - -
27: LC None - - - -
28: LC None - - - -
29: LC 10 Gig Ethernet Line Card 1 Port Active No 13
30: LC 10 Gig Ethernet Line Card 1 Port Standby - 14
31: LC None - - - -
32: LC None - - - -
33: LC None - - - -
34: LC Quad 1000 Ethernet Line Card 4 Ports Standby - 2
35: LC None - - - -
36: LC Quad 1000 Ethernet Line Card 4 Ports Standby - 4
37: LC None - - - -
38: LC None - - - -
39: LC None - - - -
42: LC None - - - -
43: LC None - - - -
44: LC None - - - -
45: LC None - - - -
46: LC None - - - -
47: LC None - - - -
48: LC None - - - -
Usuários attachados:
# show sess progress
Tuesday September 27 01:25:28 CDT 2011
3157 In-progress calls
3157 In-progress active calls
1016 In-progress calls @ ARRIVED state
0 In-progress calls @ CSCF-REGISTERING state
Recursos do sessmgr:
[# show task resources facility sessmgr all|more
Tuesday September 27 01:25:43 CDT 2011
task cputime memory files sessions
cpu facility inst used allc used alloc used allc used allc S status
2/0 sessmgr 5000 1.8% 50% 68.9M 140.0M 34 500 -- -- S good
2/0 sessmgr 1 14% 100% 322.1M 1220M 55 500 2885 21120 I good
2/0 sessmgr 6 3.4% 100% 249.7M 1220M 54 500 187 21120 I good
2/0 sessmgr 11 0.5% 100% 149.3M 1220M 49 500 0 21120 I good
Para assegurar que o serviço de usuário pré-pago esteja funcionando, deve ser checada a comunicação entre o ASR 5000 e o servidor OCS.
Traces podem ser obtidos para verificar a resposta do OCS - garantir que ele esteja concedendo as cotas aos assinantes corretamente.
Procurar por mensagens como esta no trace:
[M] Multiple-Services-Credit-Control:
[M] Granted-Service-Unit:
[M] CC-Total-Octets: 1024000 ••ß Assigned quota
# monitor subscriber next-call
Tuesday September 27 01:26:05 CDT 2011
Waiting for next call to connect...
(Q)uit, <ESC> Prev Menu, <SPACE> Pause, <ENTER> Re-Display Options
*** Verbosity Level ( 2) ***
*** Verbosity Level ( 3) ***
Incoming Call:
MSID/IMSI : 334020306424398 Callid : 055da236
IMEI : 35662803318972 MSISDN : 524611340090
Username : 524611340090 SessionType : ggsn-pdp-type-ipv4
Status : Active Service Name: ggsn-1
Src Context : gn
INBOUND>>>>> 01:27:24:600 Eventid:47000(3)
GTPC Rx PDU, from 201.144.195.67:34209 to 200.95.161.226:2123 (206)
TEID: 0x00000000, Message type: GTP_CREATE_PDP_CONTEXT_REQ_MSG (0x10)
Sequence Number:: 0xFC6E (64622)
GTP HEADER FOLLOWS:
Version number: 1
Protocol type: 1 (GTP C/U)
Extended header flag: Not present
Sequence number flag: Present
NPDU number flag: Not present
Message Type: 0x10 (GTP_CREATE_PDP_CONTEXT_REQ_MSG)
Message Length: 0x00C6 (198)
Tunnel ID: 0x00000000
Sequence Number: 0xFC6E (64622)
GTP HEADER ENDS.
INBOUND>>>>> 01:27:26:621 Eventid:81991(5)
Diameter message from 10.201.46.136:3870 to 10.233.4.70:54598
Base Header Information:
Version: 1
Message Length: 312
Command Flags: PXY (64)
Command Code: Credit-Control-Answer (272)
Application ID: Credit-Control (4)
Hop2Hop-ID: 0x0000039b
End2End-ID: 0xc52d5f00
AVP Information:
[M] Session-Id: 0019-sessmgr.porgp4Balancer;90022454;598291;4e816ccc-1302
[M] Result-Code: DIAMETER_SUCCESS (2001)
[M] Origin-Host: chargingmanager03B.hp.com
[M] Origin-Realm: chargingmanager.hp.com
[M] Auth-Application-Id: 4
[M] CC-Request-Type: UPDATE_REQUEST (2)
[M] CC-Request-Number: 1
[M] CC-Session-Failover: FAILOVER_NOT_SUPPORTED (0)
[M] Origin-State-Id: 1317104723
[M] Rating-Group: 5
[V] 3GPP-Quota-Holding-Time: 3600
[M] Credit-Control-Failure-Handling: TERMINATE (0) Protocol type: 1 (GTP C/U)
Revisar a geração correta dos CDRs.
Os arquivos devem ser gerados (o número de sequência é reiniciado):
[local]PORGP4# dir /hd-raid/records/cdr/default4
Tuesday September 27 01:27:45 CDT 2011
-rw-rw-r-- 1 root root 2154846 Sep 26 13:26 PORGP4_09_26_2011_13_26_04_7602_file61804.p
-rw-rw-r-- 1 root root 2154881 Sep 26 13:26 PORGP4_09_26_2011_13_26_13_7608_file61805.p
-rw-rw-r-- 1 root root 2154286 Sep 26 13:26 PORGP4_09_26_2011_13_26_23_7553_file61806.p
-rw-rw-r-- 1 root root 2155692 Sep 26 13:26 PORGP4_09_26_2011_13_26_31_7578_file61807.p
-rw-rw-r-- 1 root root 2159346 Sep 27 01:17 PORGP4_09_27_2011_01_17_33_6866_file66651.p
-rw-rw-r-- 1 root root 2158985 Sep 27 01:17 PORGP4_09_27_2011_01_17_49_7005_file66652.p
-rw-rw-r-- 1 root root 2140744 Sep 27 01:26 PORGP4_09_27_2011_01_26_03_8760_file1.p
-rw-rw-r-- 1 root root 2142237 Sep 27 01:27 PORGP4_09_27_2011_01_27_05_8082_file2.p
Navegue pelos links rápidos da Comunidade e usufrua de um conteúdo personalizado e em seu idioma nativo:
