Camera setting on Jabber SDK
macieknowak
Hello, We are using the Jabber SDK ( Cisco Web Communicator) on Windows. We have two cams connected to the PC. The Jabber allocates (use) two cams during the call. Is it possible to configure The Jabber only for one cam (the jabber will use one cam and the other application the second) ?
Best regards
Maciek
tinghche
Level 5
Level 5
Maciek,
What version of plugin are you using?
Isn't the SDK giving you the option in using either one?
If you check the function "refreshMMDevices()" in the sample code, you will see how a device been setup as default
Could you please provide more details, screenshot of your problem?
Howard
