Deleting local user from Unity connection using Python
shree bhagwan parashar
Community Member
Hi All,
I am able to remove the user and getting response 200. But when i login into unity connection i got that user still in unity connection.Pls see response codes from unity connection.
Response [200]>
25dbb51e-4bb5-45d3-9104-b19ad5045aca
http://XXX.XXX.XXX.XXX/vmrest/users/25dbb51e-4bb5-45d3-9104-b19ad5045aca
<Response [200]>
import requests
import json
#HTTP headers to include
UserHeaders = {'Accept':'application/json', 'content-type':'application/json','connection':'keep_alive'}
#define Alias to be removed
userAlias = 'XXXXXX'
#Define your Unity connection server URL here
UCURL = 'http://XXX.XXX.XXX.XXX/vmrest/users/?query=(alias is ' + userAlias + ')'
#Forming the request using "Request" library to submit to the server.
ObIDGetResponse = requests.get(UCURL, headers=UserHeaders, auth=('XXXXXX','XXXXXX'), verify=False)
print(ObIDGetResponse)
#Using the json dot notation call to get the JSON response from the server in a dictionary format for Python to process
UserGet = ObIDGetResponse.json()
#Extracting the specific value from the dictionary using the defined keys from the JSON response
UserObId = UserGet['User']['ObjectId']
#Printing the Object ID to console
print (UserObId)
#Definining the URL used to delete the user
deleteURL = 'http://XXX.XXX.XXX.XXX/vmrest/users/' + UserObId
print(deleteURL)
#Forming the Delete request using the "Requests" library
UltimateDestruction = requests.delete(deleteURL, headers=UserHeaders, auth=('XXXXXX', 'XXXXXX'), verify=False)
#Printing the HTTP response from the server to console
print (UltimateDestruction)
lindborg
200 would be what you'd see with a GET to that url - a DELETE that is successful would typically return a 204 (no content) - I just tried it on a 10.0 and an 11.5 server I have here and got a 204 back from both just issuing the delete via POSTMAN -
My unity connection version is 10.5.X and Python is 2.7.12  Could you please post the code. Which python version you are using ?
