How to load jabber-config.xml on the Jabber SDK
ArrayNo01
Does anyone know how to add jabber-config.xml to the jabber sdk client, I need it to load
<Policies><Network_Adaption_Enabled>False</Network_Adaption_Enabled></Policies>.
I know that the jabber client can get jabber-config.xml on CUCM via TFTP, but I don't know how to handle it on the jabber SDK.
This config is to solve the problem that the jabber SDK client dynamically adjusts the resolution during the video communication process and result the mediasense single video file has multiple resolutions. This type video file is distorted when played through VLC. We hope this config will allow the jabber sdk client to maintain a resolution during video calls.
0 Replies 0
