Jabber Bot Using Python - Response was delayed
sen2nat
We created a Jabber Bot application using Python to query the database and returning the results in HTML format. We are seeing an issue with data size limit when returning message to Jabber messenger using Jabber Bot application. The Jabber Bot application to query the database and return the results in HTML format if we ask particular request details. We are seeing some issue with data size and If the query result contains more data ( more records), Jabber is taking more time to send the output message to Client Jabber Messenger. Our program output is very quick in the console, but we are seeing issue with Jabber messenger. We wanted to check with you, Is it possible to increase data transfer memory or buffer in Jabber?. Thanks
sen2nat
Can someone help on this?
Senthil
