Jabber SDK in Java Environment
Hendy Waskito
Hi all,
I want to testing deploy Jabber SDK on my customer environment as PoC.
We have show the sample web page of some Jabber SDK feature successfully.
Currently they have ORACLE WebCenter in their environment, and they want to include this web page into it.
Does the Jabber SDK compatible to be hosted in ORACLE WebCenter (JAVA environment)?
Is there  any Jabber SDK for JAVA?
Hendy Waskito
tinghche
Level 5
Level 5
Hi Hendy,
I'm not familiar with WebCenter, but I believe as long as it handles HTML/JavaScript, the SDK should have no problem to run on top of it.
You can either have Java to generate the HTML/JavaScript output, or having SDK host as template to be called by CSM page.
Best,
Howard
