Java script errors in chrome while loading Jabber Guest Web widget
rorawat
Community Member
I am integrating jabber guest web sdk in my application. I using the steps mentioned in the dev net portal.
The widget loads and I am able to call a device on cucm but I see the following java script errors in the chrome web browser console.
208 TABRORAWAT?widget=true:1 Error in event handler for (unknown): TypeError: Cannot set property 'type' of undefined
    at postMessageToClient (chrome-extension://jbglbakaieakcdiaiabbihafndhapfki/content_widget.js:64:16)
    at chrome-extension://jbglbakaieakcdiaiabbihafndhapfki/content_widget.js:124:23
Please let me know if this is an issue and how can I fix it.
Jabber guest server version 11.0.0.37.
Rohit
tom golan
Did anyone else encounter with this? we experience the exact same issue.
Thanks in advance,
Tom
Not aware of any issues associated with this message...can you confirm the OS / browser / Jabber Guest server versions?
If there are no problems or issues it may be a benign message; if something is not working right, would recommend opening a DevNet Developer Support ticket so we can help troubleshoot in detail: https://developer.cisco.com/site/devnet/support/
