REM-Session Token API sample doesn't work
wli6
Hi team,
i tried the sample code listed in the tutorial page as below:
https://developer.cisco.com/media/remote-expert-mobile-developer-tutorials/web-sdk/08-encoding-user-to-user-data/encodin…
But when i called the init.php, the response is not as expected, with the response "HTTP Status 422" as below:
Because this is a tutorial for the REM development, it is better to make it working correctly, thanks a lot.
ewindgatcshiyou
wli6
Hi ewindgat,
finally after few tries, i find out we also need add the voice attribute, for example ...
"voice":
            "username": "assist-555123456",
            "displayName": "Bob",
            "domain": "192.168.9.118",
            "inboundCallingEnabled": false
ewindgat
Level 11
Level 11
You need to add the AED2.allowedTopic attribute, for instance....
"additionalAttributes":
            "AED2.metadata":
                "role": "consumer"
            "AED2.allowedTopic": "assist-555123456"
wli6
Hi ewindgat,
according to your comments, i added the AED2.allowedTopic attribute, but the response is the same as before ("HTTP Status 422").
Could you please contact the author of that post, he should know about the correct format of the json data.
Thanks a lot.ewindgatcshiyou
wli6
Hi ewindgat,
"voice":
