Stream not Found
gurunadhpflex
I am getting  error like "Stream not found" using jabber web sdk. It was happening very rare time. But i want to know the reason why it is happenning.
dstaudt
Not much advice we can give on the limited information.  Would recommend getting set up to collect the logs the Jabber plugin writes to the file system, described here: https://developer.cisco.com/site/jabber-websdk/develop-and-test/voice-and-video/troubleshooting/
If you cannot spot the issue (the logs are pretty detailed), you will likely want to open a ticket with DevNet Developer Support for in-depth troubleshooting help: https://developer.cisco.com/site/devnet/support
Please be prepared with details of the call scenario when the error occured, including phones/DNs involved, timestamps, call sequence, etc.  Also note CUCM and Jabber plugin/SDK versions.
