using license dump for CUPI
mmitchell2007
I am attempting to use the license dump API that is a part of CUPI. I can successfully make REST requests to various calls like vmrest/ports and vmrest/version however I cannot make a request to vmrest/licensestatuscounts. I need to get all of the 5 subsections of licensing to a database.
This the URL I am attempting to use for the license dump:
https://<ip addr>:8443/vmrest/licensestatuscounts
According to the following link this should work however I keep getting a 404 errors The requested resource is not available. which leads me to believe that the REST call is available.
Cisco Unity Connection Provisioning Interface (CUPI) API -- License Dump APIs - DocWiki
dstaudt
As of v9, UCM and Unity Connection licensing is no longer managed locally on each machine, but centrally via the Enterprise Licensing Manager service.  As a result, the /licensestatuscounts APIs which queried licensing info stored on Unity Connection in versions up to v8.6 are no longer present.
A corresponding API on ELM for programmatic query/management of license data is has not yet been published...
