How to use netconf script for multiple devices
menzies456
hi,
i'm trying to work out how to call a list of routers for a netconf python script samtest.py,
very simply shown here:
Here is my list of routers:
router_info.py
router = {"host""172.16.8.100",
          "port""830",
          "username""xx",
          "password""xx"}
router = {"host""172.16.8.200",
          "port""22",
          "username""xx",
          "password""xx"}
samtest.py
from ncclient import manager
from pprint import pprint
import xmltodict
from router_info import router
with manager.connect(host=router["host"], port=router["port"], username=router["username"], password=router["password"], hostkey_verify=False) as m:
 for capability in m.server_capabilities:
   print(capability)
At the moment this only shows a single router, what i need is a for loop but i'm not sure how best to do this.....
If I change the script to this it works but this is not scalable:
from router_info import router2
   print(capability)
with manager.connect(host=router2["host"], port=router2["port"], username=router2["username"], password=router2["password"], hostkey_verify=False) as m:
   print(capability)
Sam
There is a couple of ways to do this. Like your example, I did this with Netmiko, you can create your devices and list all in here.
devices = [{
    "device_type": "cisco_xr",
    "ip": "sbx-iosxr-mgmt.cisco.com",
    "username": "admin",
    "password": "C1sco12345",
    "port": "8181",
    "device_type": "cisco_xe",
    "ip": "ios-xe-mgmt-latest.cisco.com",
    "username": "developer",
    "port": "8181",
for device in devices:
The only way is to use an inventory file, with JSON or YAML, for example this JSON file has a few routers in and what they do in the network - in this case some were route reflectors and other clients
  "router:1": {
    "IP": "10.94.242.179",
    "type": "iosxr",
    "user": "cisco",
    "password": "cisco",
    "rr": "reflector"
  "router:2": {
    "IP": "10.94.242.171",
    "type": "iosxr",
    "user": "cisco",
    "rr": "client"
  "router:3": {
    "IP": "10.94.242.172",
    "type": "iosxr",
    "user": "cisco",
    "rr": "client"
In the code, pass in the JSON file (I did this with a try) then followed with a for loop
try:
        with open(args.inventory, "r") as f:
            device_data = json.load(f)
    except (ValueError, IOError, OSError) as err:
        merge_device("Could not read the 'devices' file:", err)
You will find some good examples like this on https://developer.cisco.com/codeexchange
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
menzies456
Thanks!
