DevNet Networking
Engage with peers and Cisco experts about networking developer tools and resources.
Browse the Community
Crosswork Automation Hub
Welcome to the Automation Hub—a collaborative space designed for the automation community to foster ...
Controllers
Community space to connect, share knowledge, and seek guidance on network controllers and related to...
Network Devices
Explore, inquire, and collaborate on network devices.
Network Platform API
Platform programmability, automation, location analytics, and integrations for Meraki and Catalyst C...
Activity in DevNet Networking
Cisco ISE Windows update remediation process
I am planning on implementing Cisco ISE. There’s no built in process for remediation of missing windows update patching. I am currently using “start a program” and passing windows update command through command line. Do you have a simpler way that st...
IOS configure replace add dhcp snooping vlan issue
Hi!Have any of you managed to use configure replace to add or remove dhcp snooping vlans without it removing active snooping entries?The switch does a 'no ip dhcp snooping vlan <vlan list>' before setting up the new config line resulting in a loss of...
developer days
Hi all, May anyone here know whether developer days will be organized in near future, or it is not decided yet or it is ended.Sorry if this information has already been made available and i missed it.Thanks and regards.
ekasnak by • Community Member
  • 616 Views
  • 3 replies
  • 1 Helpful votes
Can Early API Access be disabled after enabling it?
Hi all,We are considering enabling Early API Access (Organization > Early Access) on a productionorganization in order to use a few beta read-only endpoints related to firmware(e.g. getOrganizationDevicesSoftwareVersionsChangelogs).Before doing so, w...
shogo-seta by • Community Member
  • 203 Views
  • 1 replies
NSO Product Quality Survey 2026
Help us to shape the future of Cisco NSO.If you work with or use NSO, we’d value your feedback.Take part in our 2026 NSO Product Quality Survey and share what’s working well and where we can improve.Your input helps us to understand the NSO experienc...
ff22de06-88f7-4637-ab0b-23144ad3ee15.PNG 7c8f8b66-9207-40b4-a899-d54896fb386f.PNG
bals by • Cisco Employee
  • 535 Views
  • 0 replies
NetDocAi
I'm building NetDocAi, a tool that turns Cisco network configurations into structured documentation and highlights potential configuration issues.I'm opening a small Phase 1 beta and looking for a few people who can test it and give honest technical ...
Meraki reserved sandbox setup failing
I'm new to using devnet sandboxes. I was able to setup a Meraki reserved sandbox last week. Ever since then I have been unable to relaunch the original sandbox or launch a new one. I keep getting the following error, "Torque was not able to complete ...
codydaviz by • Community Member
  • 829 Views
  • 6 replies
DevNet CML Sandbox Bidirectional Issue
Hello Fellas, I am having an issue with the DevNet CML sandbox, when trying to connect to my local Ubuntu VM inside VirtualBox. My host computer is a Windows 10. I do have connectivity from the Ubuntu VM to the nodes inside CML. I can ping them just ...
Top Experts - Last 30 Days
