CSCuw09242 - Not able to configure more than 2 interface of ASA using ASDM 7.5.1 - 1
walter baziuk
Level 5
Level 5
when will a fix be releaed.
i use asdm 7.5(1)
i upgraded to 7.5(1) 90. same issue
will 7.4 support firepower?
rvarelac
Level 7
Level 7
Hi Walter,
The devs guys are sill working in a fixed version of this defect, most likely it will be fixed in the next major release (7.6), however at this point there is not an specfic date for the release of this version.
At this point you can downgrade the software to 7.4 or configure the interfaces manually using the console.The 7.4 version does support the firepower settings.
http://www.cisco.com/c/en/us/td/docs/security/asdm/7_4/release/notes/rn74.html
Hope it helps
-Randy-
walter baziuk
Level 5
Level 5
i have tested ASDM 7.5(1)-112
it works fine and fits the problem i had
please vote for me 5stars  if it works for you also
