CSCvo27241 - Switch unexpected reload if a wrong FED IP adjacency ri_hdl is used
cuifeng
Hi All,
a 3850 stack switch was reboot automatically.The error is same as this bug.
Oct 12 08:16:36: %PLATFORM-6-HASTATUS: RP switchover, received chassis event to become active
Oct 12 08:16:36: %HMANRP-6-HMAN_IOS_CHANNEL_INFO: HMAN-IOS channel event for switch 2: EMP_RELAY: Channel UP!
Oct 12 08:16:37: %REDUNDANCY-3-SWITCHOVER: RP switchover (PEER_NOT_PRESENT)
Oct 12 08:16:37: %REDUNDANCY-3-SWITCHOVER: RP switchover (PEER_DOWN)
Oct 12 08:16:37: %REDUNDANCY-3-SWITCHOVER: RP switchover (PEER_REDUNDANCY_STATE_CHANGE)
Oct 12 08:16:37: %PLATFORM-6-HASTATUS: RP switchover, sent message became active. IOS is ready to switch to primary after chassis confirmation
Oct 12 08:16:37: %PLATFORM-6-HASTATUS: RP switchover, received chassis event became active
Oct 12 08:16:37: %HMANRP-6-EMP_NO_ELECTION_INFO: Could not elect active EMP switch, setting emp active switch to 0: EMP_RELAY: Could not elect switch with mgmt port UP
Oct 12 08:16:37: %PLATFORM-6-HASTATUS_DETAIL: RP switchover, received chassis event became active. Switch to primary (count 1)
Oct 12 08:16:39: %HMANRP-5-CHASSIS_DOWN_EVENT: Chassis 1 gone DOWN!
Oct 12 08:16:39: %NGWC_USB_CONSOLE-6-CONFIG_ENABLE: Switch 2: Console media-type changed to default
Oct 12 08:16:41: %PLATFORM_STACKPOWER-6-CABLE_EVENT: Switch 2 stack power cable 2 inserted
Oct 12 08:16:41: %PLATFORM_STACKPOWER-6-LINK_EVENT: Switch 2 stack power protocol is up on cable 2
Do you have any idea
Leo Laohoo
Post the complete output to the following command:
1. sh version; and
2. dir crashinfo-1:
I have a similler problem as above on 9300 switch stack.
AS-C9300-01#sh ver
Cisco IOS Software [Everest], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.6.4, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Sun 08-Jul-18 04:21 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 16.8.1r [FC4], RELEASE SOFTWARE (P)
AS-C9300-BDC-T311-01 uptime is 38 weeks, 4 days, 15 hours, 10 minutes
Uptime for this control processor is 38 weeks, 4 days, 15 hours, 12 minutes
System returned to ROM by SSO Switchover
System restarted at 18:37:34 KSA Sat Jul 6 2019
System image file is "flash:packages.conf"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-essentials Permanent network-essentials
dna-essentials Subscription dna-essentials
cisco C9300-48U (X86) processor with 1392685K/6147K bytes of memory.
Processor board ID FOC2247Q0WA
36 Ethernet interfaces
7 Virtual Ethernet interfaces
212 Gigabit Ethernet interfaces
52 Ten Gigabit Ethernet interfaces
10 Forty Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
1638400K bytes of Crash Files at crashinfo:.
1638400K bytes of Crash Files at crashinfo-3:.
11264000K bytes of Flash at flash:.
11264000K bytes of Flash at flash-3:.
0K bytes of WebUI ODM Files at webui:.
1638400K bytes of Crash Files at crashinfo-1:.
11264000K bytes of Flash at flash-1:.
1638400K bytes of Crash Files at crashinfo-4:.
11264000K bytes of Flash at flash-4:.
1638400K bytes of Crash Files at crashinfo-5:.
11264000K bytes of Flash at flash-5:.
Base Ethernet MAC Address : 70:c9:c6:d7:5b:00
Motherboard Assembly Number : 73-18275-04
Motherboard Serial Number : FOC224665V6
Model Revision Number : A0
Motherboard Revision Number : A0
Model Number : C9300-48U
System Serial Number : FOC2247Q0WA
Switch Ports Model SW Version SW Image Mode
1 62 C9300-48U 16.6.4 CAT9K_IOSXE INSTALL
* 2 62 C9300-48U 16.6.4 CAT9K_IOSXE INSTALL
3 62 C9300-48U 16.6.4 CAT9K_IOSXE INSTALL
4 62 C9300-48U 16.6.4 CAT9K_IOSXE INSTALL
5 62 C9300-48UXM 16.6.4 CAT9K_IOSXE INSTALL
Switch 01
Switch uptime : 14 hours, 3 minutes
Base Ethernet MAC Address : 70:18:a7:6f:67:00
Motherboard Serial Number : FOC2243A9RE
System Serial Number : FCW2245E0GA
Switch 03
Switch uptime : 38 weeks, 4 days, 15 hours, 15 minutes
Base Ethernet MAC Address : 00:29:c2:04:61:00
Motherboard Serial Number : FOC224665B5
System Serial Number : FOC2247Q0WQ
Switch 04
Switch uptime : 14 hours, 2 minutes
Base Ethernet MAC Address : 70:18:a7:6f:81:00
Motherboard Serial Number : FOC2243A9XA
System Serial Number : FOC2245Q0G8
Switch 05
Base Ethernet MAC Address : 70:18:a7:6d:21:00
Motherboard Assembly Number : 73-18277-04
Motherboard Serial Number : FOC224465J3
Model Number : C9300-48UXM
System Serial Number : FCW2245D0J6
Configuration register is 0x102
Hello
I have two version on my infraestructure C9200 y C9300 with the same problem with three switches on stack, the version 17.9, reload my switches when I configured some command, what is the solution to solve this BUG ?
