CSCvr27850 - External authentication using LDAP and Radius fails for SSH access on the FTD
rgregedwards
I'm still experiencing this issue (template LDAP.CONF file on FTD devices) with version 6.6.0.1-7 FMC and FTD.  LDAP (to AD) works for the FMC, but not the FTD 2110s....  Anyone else?Cisco Bug Discussions, Cisco Bugs
Sheraz.Salim
This bug also exists in version 7.0.x
working with TAC Engineer will provide the update how to fix/workaround this bug.
please do not forget to rate.
Hi Sheraz, can you please post any update on this? Thanks.
you try to access SSH via mgmt interface or data interface ?
MHM
No its Bug. SSH work but LDAP (external Authentication) does not work. only way to login is local user. working with TAC. as this Bug identitiy was close in version 6.6 but it showed up in version 7.0.x too.
