RV34x firmware version: 1.0.03.15 PPTP connection issue
pakhong
I am stuck at setting up VPN > PPTP connection between RV345 and Android devices. To simplify this problem, I made minimal changes started from clean factory configuration with firmware version: 1.0.03.15.
WAN1 IP: 192.168.0.240 (located within the same subnet to the Android device to be connected, IP: 192.168.0.133)
user name: cisco
password: cisco
group: admin (PPTP enabled)
System Summary
PPTP server authentication sequence: Local DB3.jpg
PPTP server
Android version 8.1.0 setting (IP: connected to the same subnet to RV345’s WAN1, ie. 192.168.0.133)5.jpg
It looks to me the authentication sequence is going through Radius server instead of Local DB. Am I missing any settings?
Thanks.
0 Replies 0
