ip subnet calculator
cleverjunkis99
hi,
i would like to ask you about ip subnet calculator, in my case i can't use it even when i'm connected whit my id.
Cisco tells that's free to use, but i see that's not.
thank you.
Please answer me, as soons as possible
5 Replies 5
Leo Laohoo
The people who respond to threads are VOLUNTEERS.  We are not paid by Cisco and we are all here on our own time.
If you require an immediate response, please feel free to raise TAC Case.
hi
you can calculate no of subnet in your fingure tip so simple try it.
Ans. It depends upon how many bits are taken from host id foe example we use 11000000 means we use 2 bits from host id then no of subnets are 2^n where n is the no os bits taken from host id in this example is 2 then the subnets are 2^2=4 and the no of user per subnet is calculated from this method if no of unused bits are 6(shows in example) then hosts are 2^6 - 2 = 62 hosts.
try more........
Manish Mishra
Spooster IT Services
saif musa
Level 4
Level 4
Which ip subnet calculator do you mean ? could you just past its link here ??
mionan
If you want a free subnet calculator just go here http://www.subnet-calculator.com/
Hi we can try this below link subnet calculator
http://jodies.de/ipcalc
Thanks and Regards
      D.Subhash
