ISDN BRI incoming calls to SIP server not working
manoj_Japan
Hello
I have configuring Cisco 2811 router which has ISDN BRI line. Outgoing calls are working fine but somehow incoming call not route to the SIP server. on SIP server SIP trunk configured with trunk number 0473920062.
Bellow is the configuration. I have attached debug file.
Any support would be highly appreciated.
Building configuration...
Current configuration: 2730 bytes
! Last configuration change at 13:59:50 UTC Sun Nov 18 2018 by admin
version 15.1
service config
hostname VGTOK01
boot-start-marker
boot-end-marker
no aaa new-model
no network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 2
dot11 syslog
ip source-route
ip cef
ip domain name kkleads.com
no ipv6 cef
isdn switch-type primary-ntt
voice service voip
allow-connections sip to sip
sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8 bytes 40
codec preference 3 g723r63 bytes 96
codec preference 4 g726r16 bytes 80
voice-card 0
license udi pid CISCO2811 sn FHK1438F2K3
username admin privilege 15 password 0 gateway2000
redundancy
controller T1 0/0/0
controller T1 0/0/1
ip ssh version 2
interface FastEthernet0/0
ip address 192.168.1.205 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface BRI0/1/0
no ip address
isdn switch-type ntt
isdn point-to-point-setup
isdn incoming-voice voice
interface BRI0/1/1
no ip address
interface BRI0/2/0
no ip address
interface BRI0/2/1
no ip address
ip default-gateway 192.168.1.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.1
nls resp-timeout 1
cpd cr-id 1
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/2/0
voice-port 0/2/1
mgcp profile default
dial-peer voice 20000 voip
preference 1
destination-pattern 047.......
session protocol sipv2
session target ipv4:192.168.1.200
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 10000 pots
preference 2
destination-pattern .T
port 0/2/0
dial-peer voice 10001 pots
preference 1
incoming called-number .
direct-inward-dial
port 0/1/0
sip-ua
authentication username 10000 password 7 14474B5A28550F7E7D7C6A6077
retry invite 3
retry response 3
retry bye 3
retry cancel 3
timers expires 300000
registrar ipv4:192.168.1.200 expires 300
sip-server ipv4:192.168.1.200:5060
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
login local
transport input ssh
scheduler allocate 20000 1000
end
VGTOK01#
0 Replies 0
