MPO Cable Compatibility
Gohar
I have two queries regarding MPO cables connectivity.
I want to know the exact MPO cable, Type ( A/B ) , Connector (Female / Male ), Mode ( Single / Multi ).
1. Which MPO-24 Cable may use for back to back ASR-9K 100G connectivity through CPACK-100G-SR10  ????
2.  Which MPO-12 Cable may use for back to back Nexus-9K 40G connectivity through QSFP-40G-SR4-S
retwaru
For:
I just used MPO-12, type-B and it work.
For:
I just used MPO-24, type-A and it work.
Hi Gohar,
Your question: MPO-24 Cable may use for back to back ASR-9K 100G connectivity through CPACK-100G-SR10?
For a direct connection between two CPACK-100G-SR10 you will need a multimode 24 fibre cable with 24 fibre MPO female connectors on both ends. The polarity of is not A, B or C. I don't think it has a designation within the standards. We call it Polarity X for 100G SR10 and it pairs the fibres connector top row and bottom row together. I think the Cisco transceivers use the MT ferrule so you are best using an MTP - MTP cable (which use the same ferrules) and not generic MPO cable. We have these in various lengths in stock.
https://www.completeconnect.co.uk/products/100g-base-sr10-mtp-mpo-fibre-patch-cable/
This would be a Polarity Type B MPO (female) to MPO (female) 12 fibre multimode cable. Again you would be best using one with MTP connectors. https://www.completeconnect.co.uk/products/mtp-patch-cables-fibre-OM3/
Hope that helps
