Cisco CLI Anaylyzer 3.2.1
Eric R. Jones
Level 8
Level 8
I just updated my laptop to Windows 10 and installed Cisco analyzer. I updated it to 3.1 and now after it starts if I select anything in the window after logging in the application crashes. Literally if I select the window edge it will crash.
This isn't happening on my other Win10 box just this laptop so far.
Anyone have these issues?
CLI Analyzer v3.2.1
Windows 10
HP laptop
victor.lopes
Community Member
Hello!
I have the same similar problem. After installation Cisco-CLI-Analyzer.3-2-1.x64.msi never open! After run .exe the application crashes in loading screen.
This issue happen in my laptop and another one too in my company.
Win 7 Pro 64
Lenovo E430
Victor,
Can you try manually updating via the following to see if that helps.
Reboot and then attempt relaunch....
Kevin W.
Hi Kevin,
Works fine now!
Ty,
Victor.
