Cisco CLI Analyzer
Find tools and resources to streamline your service and parts logistics questions, technical documentation and bug discussions.
Activity in Cisco CLI Analyzer
What if you could just tell Packet Tracer what to build?
Hi everyone, I’m working on an idea and I’d like to hear what people in the field think.the idea : an agent that controls Packet Tracer for you. You give it a document (a lab, a TP, a requirements sheet) or just write a message like “build 2 routers,...
potchioussa by • Community Member
  • 321 Views
  • 4 replies
CLI Analyzer does not use the configured proxy
Hi,I installed CLI Analyzer 3.7.2 on a Windows host. On first run, it popped up an error "Internet can't be reached" so I went to the Advanced settings and configured my proxy (HTTP, URL and port).After restarting the application, the error is still ...
herbert-b by • Frequent Visitor
  • 1776 Views
  • 4 replies
Cisco 3110 unable to determine the device information
Getting this on a Cisco 3110 after about 10 minutes:Last login: Wed Oct 8 18:32:03 UTC 2025 fromSuccessful login attempts for user Last login: Wed Oct 8 19:04:32 2025 fromCopyright 2004-2024, Cisco and/or its affiliates. All rights reserved.Cisco is ...
sdemlow007 by • Frequent Visitor
  • 1007 Views
  • 1 replies
CLI Analyzer 3.7.3 - Slow
Why is CLI Analyzer so slow when opening new SSH connections?Then when you are connected It also feels like there is a bit of input lag.Is there something I am doing wrong or is it like that for everyone?
CLI Analyzer 3.7.2
Where is the CLI Analyzer 3.7.2 download? I checked https://cway.cisco.com/cli/. When you click Help in the top right corner, it references a March 2024 build of 3.7.2, however when you go to download, only 3.7.1 is available from last year. Attached...
What does the Activity Type Data mean in the CSR report?
I have created a CSR report on Cisco Analyzer to capture all calls reaching our customer service department.When I look at the Activity Type data, I do not fully understand what the values represent.The data I have is:- Advance Queue Menu- Disconnect...
jeflores by • Visitor
  • 731 Views
  • 0 replies
Error reading from file
HII'm attempting to install Cisco CLI Analyzer version 3.7.2 on a Windows 11 (x64) machine, but I'm encountering the following error during installation:Error reading from fileC:\Users\Downloads\Cisco-CLI-Analyzer-3-7-2.x 64.msiVerify that the file e...
With large show tech files, don't work
I have problem when I use show tech files (example: show tech of Nexus or stacks with 5 or more devices). Then of press "START ANALYSIS" button, I have as result only 1 info with the leggend: "Unable to determine the output you provided. Ensure you p...
CLI Analyzer 3.7.2 - error 471 again?
Today (19.08.2025) I'm not able to check any file or logs.  Do you know what's happening? In previous tickets I did not find any solutions for that error.  Same problem is on CLI Analyzer 3.7.1 - checked right now.
PMI17 by • Frequent Visitor
  • 998 Views
  • 0 replies
Resolved! Cisco CLI Analyzer Device version update refresh
After updating the IOS of devices CLI Analyzer doesn't refresh the devices page to refelect the new IOS version.   I.e Cisco ASA upgraded 8.4 to 8.6 but CLI Analyzer doesn't refresh to display new IOS.   Is there any workaround for this?
daburAGG12 by • Frequent Visitor
  • 3807 Views
  • 2 replies
Resolved! Export CLI analyzer diagnostic results
Hi team,I'm currently working on updating our vulnerability management process. (Well there was virtually none and very reactive.)I've just configured ManageEngine NCM to generate exposed devices report which shows the Model, OS type, OS version and ...
atsukane by • Level 7
  • 2647 Views
  • 2 replies
Top Experts - Last 30 Days
