CLI Analyzer - Can't run UCS System Diagnostics - Self Signed Certificate in Chain
joostbuelens
Frequent Visitor
Frequent Visitor
The new CLI Analyzer UCS B Health Diagnostics sounds like a really great tool, I've tried to run to run it against a number of systems now, and it always fails with the message below:
* Cisco UCS-B System Diagnostics: Error: Failed to login to https://ucs.fi.dns/nuova via XML API. Reason: self signed certificate in certificate chain. Failed to login to http://ucs.fi.dns/nuova via XML API. Reason: No cookie received from device.
At first I thought this was happening because the UCS systems we look after all have self signed certificates, but after setting some systems up with 'proper' certificates from an internal CA, I'm still seeing the same issue.
Is there an option I can set somewhere that ignores the certificate? Or some other workaround?
Joost
0 Replies 0
