CLI Analyzer Jumphost login uses RSA Secureid 2 factor Token validation.
hht-cco-ibm
Community Member
Is it possible to configure CLI Analyzer Jumphost record for jumpserver login where 2 factor RSA Token is mandatory?
Has only found the normal Keyboard intercative Userid/password or Trusted Key options.
I can not access my Cisco devices directly. So the tool has to be able to setup a jumphost connect sequence where i interactively can enter the actual pin+tokendisplay combination
0 Replies 0
