CLI Analyzer Launch Variables
smcanulty
Visitor
I am looking to launch CLI Analyzer from an external program and pass the host information. Does anyone know if this is possible and what the string to append would be?
To give an example, in PuTTY if you pass it "-ssh %host", it would launch PuTTY and connect to the host with SSH. This makes investigating alerts from our monitor very easy.
kevwilso
See the following section from the user guide
https://cway.cisco.com/docs/cisco-cli-analyzer/latest/Initiate_an_SSH_Session_from_the_Command_Line.htm?rhsearch=command%20line&rhsyns=%20
You might already know this but if you click on "Feature Guide" on the bottom left, you'll be taken to in-app documentation which has text, images, and videos.
Kevin W.
kevwilso
Kevin W.
