proposals
psmidcnss
Good morning,
thank you for this tool, version 3.1.0 brought some interesting features.
I noted the copy/paste functions are working properly only using contextual menu (rigth click); CTRL+V for pasting works only sometimes, if I choose the option "putty" in the copy/paste settings it doesn't copy on selection as I expect.
A couple of proposals:
- I'd like if I could send a text on many sessions at the same time.
- I'd like also if I could have a quick set of commands that I could recall (e.g. many buttons)
Thank you
mc
John Bollier
   Thank you for your suggestions and letting us know about the pasting issue. Our support team will be contacting you directly to investigate the paste issue.
Regarding the proposals:
- Send text to many sessions: We have something similar to this on the roadmap and would allow more flexibility/granularity when needing to update multiple devices.
- Quick set of commands: This is also on our roadmap. In addition to simple commands you could paste comprehensive changes that encompass several lines.
If you have any other issues or suggestions feel free to submit using the "Feedback" option within the CLI Analyzer. This helps ensure a prompt response as that will get it to our support team.
Best regards,
John
Thank you a million John!
Kind regards
Marco Canova
I'd like to a address a proposal, too
  1. the mark/select behavior is not like I'm used to (putty/notepad++/...)
    -> to mark parts en-block is helpfull if you have to collect data for further investigations, I miss this possibility
  2. it would be nice to ping devices directly from the devices-inventory (one and/or selected)
  3. a device-inventory export including the 'ip', 'hostname', 'location' + 'model' and 'version' would be nice
  4. Tools: it could be helpfull to be able to define custom tasks (e.g. for offline data collection)
