BGP regular expresion match sequence
fcardoso
I want to block paths that contain exactly 8 consecutive repetitions of AS 64601, even if they are preceded or followed by other ASes (like in the example 5555 64601 64601 ... 66666)."
Tanks
Antonio
Hello @fcardoso
You seem to be right about that (another) limitation on that platform...
So, if you want to match 8 instances of 64601 with no shortcut with {8} quantifier ; you should list them one by one separated by _ ?
Best regards
11 Replies 11
M02@rt37
Hello @fcardoso
You want to do this on which platform and which IOS ?
Best regards
Yes, in IOS XE
The platform ia a ASR 903
Ok @fcardoso , Thanks.
Regarding this doc: https://www.cisco.com/c/en/us/td/docs/security/security_management/cs-mars/4-3/user/guide/local_controller/appreexp.html
you could use {n} regex like this:
ip as-path access-list 10 deny ^64601{8}_
ip as-path access-list 10 deny _64601{8}$
ip as-path access-list 10 deny ^64601{8}$
This entries will block any BGP path that contains exactly 8 consecutive occurences of AS 64601.
Apply this on a RM:
route-map FILTER_Deny-8x64601 deny 10
match as-path 10
route-map FILTER_Deny-8x64601 permit 20
router bgp #ASN#
neighbor #NEIGH.IP# route-map FILTER_Deny-8x64601 in
Best regards
Hi, thanks very mutch for the help...
I did a simple text:
#sh bgp vpnv4 unicast vrf xxx
64601 64601 64601 64601 64601 64601 64601 64601 66666
then:
#sh bgp vpnv4 unicast vrf xxx regexp ^64601{8}_
and it didn't work, did not receive anythink....
that is, the following sequence should have appeared:
the ios version16.09.04 and the platform ASR-903 (RSP3_200) maybe is not compatible with  metacharacters like {}...
Best regards
Hello @fcardoso
Best regards
I will check this point I will reply tonight.
Please confirm if you still interest for answer
MHM
Yes I'm still interested...
thank you very much for your help..
Antonio
ip as-path access-list 20 deny _64601 +64601_
Try above
Update me
MHM
The expression currently denies all AS paths that contain AS 64601 anywhere in the path, even if it's not repeated. However, the intended behavior was to deny only the paths that include exactly 8 consecutive repetitions of AS 64601
Antonio
^64601( /1){7}_
Or
_64601( /1){7}_
Check these two
MHM
{n} seem to be not available on that platform...
Best regards
