How to reset cisco router 2900
akhonajokani
Hi there
we have a cisco router that we forgot the username and password to access it.  please help to reset it.. we have tried the ctrl pause break , it did not work. It ended on the cold start.
Blue_Bird
Hello akhonajokani,
Pleas follow the link which will help you to resetting your router:
https://community.cisco.com/t5/networking-knowledge-base/resetting-router-to-factory-default-removing-the-startup/ta-p/3131114
Best regards
******* If This Helps, Please Rate *******
