Firmware for SG 200-26P
waltasan
Hello everyone,
I'm new in here and just found out that the above mentioned switch is no longer supported by Cisco. This also means that I can't download firmware versions which are newer than mine (1.0.0.19). Anybody here who can help me out with newer firmware versions I can install? I only use the switch privately, so in my humble opinion no need for a new one, as this one still works perfectly fine.
Thank you in advance for coming back to me.
Kind regards,
waltasan
waltasan
Hi everyone,
Got this sorted myself.
You have to check the download page, expand "All release" and then expand "1" (yes, that's where I found further firmware versions between the ones mentioned above). Awkwardly sorted, but at least I was able to solve this. Hope this helps.
Cheers
5 Replies 5
waltasan
Hi everyone,
Cheers
waltasan
Edit: forgot to mention, the download page shows by default 3 firmware versions, 1.1.2 and 1.4.x, these are the firmware versions I meant by "the ones mentioned above". Sorry for not being precise enough in my posts above.
rhadge
how to get release version
Hi @rhadge ,
What do you mean with "release version"? Please be more specific.
Kind regards
