IP SLA Email generation for up and down using EEM
kshenk
I currently have the following configuration for IP SLA and EEM notifications.
track 1 ip sla 10 reachability
 delay down 90 up 90
ip sla 10
 icmp-echo 172.20.1.9 source-interface GigabitEthernet0/0/1
 frequency 5
 history distributions-of-statistics-kept 2
 history buckets-kept 60
 history enhanced interval 10 buckets 10
ip sla schedule 10 life forever start-time now
ip sla reaction-configuration 10 react timeout threshold-type immediate
ip sla logging traps
ip sla enable reaction-alerts
event manager environment _email_server 1.1.1.1
event manager environment _email_from JOE@
event manager environment _email_to SUZY@
event manager applet ISPCHECK
 action 1.0 if $_ipsla_condition eq "Occurred"
 action 1.1  syslog msg "Primary Internet Circuit Down"
 action 1.2  mail server "1.1.1.1" to "SUZY@" from "JOE@" subject "Circuit Down" body "Primary Internet Circuit Down."
 action 1.3 else
 action 1.4  syslog msg "Primary Internet Circuit UP"
 action 1.5  mail server "10.0.0.12" to "it@cleburne.net" from "pdalerts@cleburne.net" subject "Circuit Up" body "Primary Internet Circuit Up."
 action 1.6 end
The issue is I cannot enter the command for
event ipsla operation-id 10 reaction-type timeout (IT IS NOT AVAILABLE)
I get this in logging history
entry number 160 : HA_EM-4-FMPD_NO_EVENT
    No event configured for applet ISPCHECK
Is there a different command I need to use or is the configuration incorrect?
it will appear when event occur. The when track move state from up to down or down to up.. :)
Jaderson Pessoa
*** Rate All Helpful Responses ***
7 Replies 7
Jaderson Pessoa
@kshenk Hello,
this can help you better.
R1(config)# event manager applet ISPCHECK
R1(config-applet)# event track 1 state down
R1(config-applet)# action 1.0 syslog msg "Primary Internet Circuit Down"
R1(config-applet)# action 1.2 mail server "1.1.1.1" to "SUZY@" from "JOE@" subject "Circuit Down" body "Primary Internet Circuit Down." from "eem@lab-exam.net" subject "User-Issue" body "$_cli_result"
R1(config-applet)# event track 1 state up
R1(config-applet)# action 1.3 syslog msg "Primary Internet Circuit UP"
R1(config-applet)# action 1.4 mail server "10.0.0.12" to "it@cleburne.net" from "pdalerts@cleburne.net" subject "Circuit Up" body "Primary Internet Circuit Up."
R1(config-applet)# action 1.5 end
Jaderson Pessoa
Thanks Jaderson,
I actually was in process of trying that and just finished the script when I do Show track 1 it doesn't look like it is being tracked by the ISPCHECK.  Config below, am I still missing something or does something else have to happen?
event manager environment _email_from Alert@
event manager environment _email_to it@
 action 1.1  mail server "1.1.1.1" to "it@" from "alert@" subject "Circuit Down" body "Primary Internet Circuit Down."
 action 1.2 else
 action 1.4  mail server "1.1.1.1" to "it@" from "alert@" subject "Circuit Up" body "Primary Internet Circuit Up."
 action 1.5 end
CLEBURNEVPN#show track 1
Track 1
  IP SLA 10 reachability
  Reachability is Up
    4416 changes, last change 14:59:25
  Delay up 90 secs, down 90 secs
  Latest operation return code: OK
  Latest RTT (millisecs) 9
  Tracked by:
    Static IP Routing 0
@kshenk Hello,
I cant see your event track.
 action 1.5 end
Jaderson Pessoa
Also wanted to mention the IP SLA works just fine has been for a while.  Thanks
Great,
you can also divide them.
R1(config)# event manager applet ISPCHECK_DOWN
R1(config-applet)# action 1.1 syslog msg "Primary Internet Circuit Down"
R1(config-applet)# action 1.3 end
R1(config)# event manager applet ISPCHECK_UP
R1(config-applet)# action 1.1 syslog msg "Primary Internet Circuit UP"
R1(config-applet)# action 1.2 mail server "10.0.0.12" to "it@cleburne.net" from "pdalerts@cleburne.net" subject "Circuit Up" body "Primary Internet Circuit Up."
If possible mark as solved and helpful.
Jaderson Pessoa
Had to remove end action, I will have to see if this works in testing still don't understand why the show track 1 doesn't show the eem as what it is tracked by.
Thanks Reply and I will accept as answer.
Jaderson Pessoa
