Networking project on cisco packet tracer
utkrishtkashyap
I am new to cisco packet tracer. I have to design network layout for software development company in packet tracer  3 departments all located at different location (apart from each other)
Do i have to use intervlan routing to create vlan to use resources on local network?
Which one is best routing protocol for this project ospf or other?
I have to provide security to the network using port security & server on one location should be accessible to all departments
One department should not have access to web server how to do that?
Please help me...
luis_cordova
Hi @utkrishtkashyap ,
You can divide the 3 departments using VLANs, allowing traffic between vlan through intervlan routing using a switch layer 3 (configuring SVIs) or using a router (configuring Router-On-A-Stick).
OSPF is a good routing protocol, compatible with different brands. If you are more familiar with this protocol, I recommend using it.
Port-security is activated with these commands:
Sw(config-if)#switchport port-security
Sw(config-if)#switchport port-security maximum <MAC number per port>
Sw(config-if)#switchport port-security mac-address sticky
Sw(config-if)#switchport port-security violation restrict
The filter between networks or devices must be done using ACLs
You are welcome.
Remember to mark the correct answers as solved, because that helps other users with similar questions.
