packet tracer login failure, please help
Translator
Community Manager
Community Manager
When I try to log in to Packet Tracer, it says "Please use netacad.cn to access the Cisco Networking Academy program", how do I fix it? I'm from China.
Translator
Community Manager
Community Manager
It is possible that your cco account does not have netacad privileges, and that your own cco account does not have netacad privileges. If you don't use a lot of guest login, you can wait a dozen seconds to get into the program
Or try to download version 8.2.0, version 8.2.0 support the use of skillsforall.com account login (domestic access is slow, can find a scientific way to access the Internet), you can avoid the netacad account problem, register the account can not select the current china, directly select a different region can be.
 pt8.2 download address: https://skillsforall.com/resources/lab-downloads
