Packet Tracer problem
EP20
Community Member
hello guys, as the title says, im currently having a problem with a simulation in packet tracer; i basically created 3 networks, each with two hosts and connected to a switch, the main goal is to be able to send PDU's across routers through static routing, however, when i start the simulation, the PDU's can't get past the main router, i double checked everything and i don't know what went wrong, anyone got a solution? i can send screenshots of the various configs if necessary
Hi @EP20
The command for static routes is:
ip route <destination network> <mask> <output interface>
Try this:
Router0
Router(config)#ip route 192.168.5.0 255.255.255.0 serial 2/0
Router(config)#ip route 180.12.0.0 255.255.0.0 serial 3/0
Router1
Router(config)#ip route 172.18.0.0 255.255.0.0 serial 2/0
Router2
Router(config)#ip route 172.18.0.0 255.255.0.0 serial 3/0
luis_cordova
Hi @EP20
Compress your exercise (winzip) and attach it to review
Hi @EP20
Try this:
Router0
Router1
Router2
hey dude, i tried your settings and it worked, thank you very much.
