WS-C2960+24TC-L V05 and V02 same firmware IOS did not works.
gabor.termecz
Dear Community,
  I had a problem with WS-C2960+24TC-L Version 05. I tried to boot from C2960-lanbasek9-mz-152-6.E1.bin and E3 and did not works. Restarting all the time after booting new IOS image. If I try the same WS-C2960+24TC-L V02 but Version 02 modell, evrything looks great. Is that possible Version 05 did not works with 15.2.XX IOS images?
V05 shipped with 15.0(2)SE (i'd like to go 152-6.E1 >> our company supported this version)
V02 shipped with 15.2(2)E8 (this version works well)
Anyone faced similar symptom?
Best Regards,
Gábor
trakimanhminh
Well, I have just meet the same issue like yours. But in my case, the item is WS-C2960+24PC-S. When I enter the command show version, it appear like this:
Base ethernet MAC Address : F0:25:72:72:48:80
Motherboard assembly number : 73-12619-04
Power supply part number : 341-0266-03
Motherboard serial number : FOC14444BPA
Power supply serial number : LIT22360KGG
Model revision number : F0
Motherboard revision number : A0
Model number : WS-C2960+24PC-S
System serial number : FOC2201Y2JZ
Top Assembly Part Number : 800-32808-01
Top Assembly Revision Number : A0
Version ID : V02
CLEI Code Number : COMS410ARB
Hardware Board Revision Number : 0x02
Switch Ports Model SW Version SW Image
* 1 26 WS-C2960-24PC-L 12.2(55)SE12 C2960-LANBASEK9-M
I have no idea if this is the mistake from Cisco production or anything else. My solution in this case is load the OS of WS-C2960-24PC-L for it, and it works well.
