Securex Dashboard Integration tiles
lschwabd
Hi i'm working on an intregation and I want to import some data to securex dashboard.
I'm following this devnet tutorial > https://developer.cisco.com/learning/modules/securex-serverless-relay-modules/SecureX-7-Dashboard-Tiles/different-securex-dashboard-tile-types/ and my question it's how can i customize the graphics colors and how can i color the cell background in the markdown tiles. What lib is Securex using to create the dashboard tiles?
https://github.com/CiscoDevNet/security-api-workshop-resources/blob/master/securex/SecureX-7/second-lab/5-tile_markdown.py
randalpinto
Did you find any further information on this? Also, in your screenshots your tiles have an icon next to their names, what attribute do i need to set to display an icon? The link you posted to the tutorial no longer seem to be active.
Hi, randal
No, I did not find any other information on that. My understanding at time was that they used an limited version of the markdown.
What icon are you referring to?  These ✓ , ✘ are letter
