Roaming Computers Settings API Calls
Pradeepkumar DS
Hi Team,
I've gone through the documents w.r.t API, There are API's for creating 'Network Tunnel', 'Monitor Tunnel', Like wise 'Destination Lists' etc., on Umbrella dashboard.
I'm looking for API which can get into the 'Roaming Computers' > Settings > Backoff Settings.
For Example: Toggle Enable or Disable under 'Backoff Settings' through API Call. Any pointers for the same, please let me know?
Torbjørn
I unfortunately don't think that this functionality is exposed through the public documented API at all. I might be wrong however, the Umbrella API is not something I get to work with every day. I would contact someone working on the product within Cisco to figure out how you best can solve what you need for your usecase(and please report back with the solution if you do!).
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
