9300 python question
fm235
Frequent Visitor
Frequent Visitor
I'm using the guest shell in on a 9300 and trying to save a run config txt file and then print out the run config txt file in the python interpreter. But it's not working, see below:
>>> cli_output = cli("sh run")
>>> type(cli_output)
<type 'str'>
>>> f = open("run_config.txt" , "w+")
>>> f.write("cli_output")
>>> print f
<open file 'run_config.txt', mode 'r' at 0x22b4d20>
I'm expecting to see the run config file print out on the interpreter but it's not happening.
Also how can I scp this file over to my desktop? Do I need to copy it over the switch directory? Not sure how that's done.
5 Replies 5
yawming
>>> print f
for line in f:
    print (line)
fm235
Frequent Visitor
Frequent Visitor
Thanks for the reply, so I tried the for loop and getting the below:
>>> f = open("run_config1.txt" , "w+")
>>> f.write("run_config")
>>> for lines in f:
... print (lines)
>>> f1 = f.readlines()
>>> for lines in f1:
... print lines
Don't think I'm getting the right result?
yawming
Maybe close file and open again
f.close()
f = open("run_config1.txt" , "r")
for line in f:
    print (line)
fm235
Frequent Visitor
Frequent Visitor
I see the issue when I just try reading the file, it only outputting "cli_output" , it's not storing the value of the variable in the file:
>>> f = open("run_config.txt" , "r")
>>> contents = f.read()
>>> print contents
cli_output
how can I pass the contents of the variable to my txt file?
TI2491
Community Member
So i'm not sure if this is it, but in you're first post, you're doing
did you mean
f.write(cli_output)
could have something to do with it.  after this test, would you mind pasting the results of a
dir() and vars()
on both cli_output and f after the write?
