About Plug and Play using C2960CG
Keisuke.I
I can not do PnP, The following message is displayed.
  Device disconnected probably due to incorrect certificate or TLS version
The following is the IOS and model number used.
  IOS : c2960c405ex-universalk9-mz.152-2.E8.bin
  Model number : WS-C2960CG-8TC-L
Is PnP possible using C2960CG?
Keisuke
Leo Laohoo
2960CG do not support PnP.
Leo Laohoo
Hello Leo,
Thank you for the information.
The following site states that PnP can be done, but is it old information?
https://www.cisco.com/c/ja_jp/support/cloud-systems-management/dna-center/products-device-support-tables-list.html
Keisuke
I believe that is talking about the SmartInstall.
This feature has been permanently disabled if the appliance is running an IOS that was released after June 2018.
You were right.
The list on the site turned out to be wrong.
