Can't get Interface0/0/x params - via GET method - with remote management container - IOS XE
I'm trying to get get interface shwo ip int GigabitEthernet0/0/4 params via a HTTP Get method, and I do always get a response 404 NOT Found.
In the request I used the URI : https://10.10.10.9:55443/api/v1/interfaces/GigabitEthernet0%2F0%2F2
(I changed the / on the interface name with %2F).
When I do a request to get the params of GigabitEthernet0 it does work, and I do have the 200OK response with the JSON formated params of the interface.
You find in the attachement the screenshots of the request, and the show virtual-service output.
Thanks in advance for your help.
0 Replies 0
