Defining same credentials for al elements in pyATS testbed.yaml file
oslopez
Level 3
Level 3
I have a network where all the network elements have the same login credentials, therefore my testbed.yaml file looks like this (excerpt):
testbed:
devices:
  NX7k_01:
    connections:
      cli:
        ip: 10.1.8.40
        protocol: ssh
        port: 22
    credentials:
      default:
        username: cisco
        password: "%ENC{w5jDrsOGw6HDlMOCwpzCmw==}"
    type: Nexus9000v
    os: nxos
  ASR_1001_01:
    connections:
      cli:
        ip: 10.1.8.10
        protocol: telnet
        port: 23
    credentials:
      default:
        username: cisco
    type: ASR1001-X
I would like to know if there is a way to define the credentials section only once for all the elements so that I don't have to define them over and over again. What would be the syntax for that?
Thanks.
oslopez
Level 3
Level 3
Ok just had a look at pyATS documentation and it was just a matter of moving the credentials section above devices section so that the credentials apply to all devices. That solved the problem.
oslopez
Level 3
Level 3
sacks
Just curios, is it possible to pass multiple strings to password field ? Incase login with one password fails, we can try with next set of passwords. Need this logic for a specific usecase.
