Genie issue
I installed genie in rhel7 server using pip the python version is 3.6. However when I try to run genie on the cli it gives me the following error
File "src/unicon/core/pluginmanager.py", line 18, in init unicon.core.pluginmanager
ImportError: cannot import name supported_chassis
Has anyone had this issue? and is there a solution to this? I get the same error when i try pyats as well
#genie, #pyats
I emailed the dev team using the email you suggested and their response was quick and gave me a proper solution as well.
Uninstall unicon and install unicon and unincon.plugins and it worked.
Both were installed using pip
IreneZ
I found their support email address: [email protected] from https://github.com/CiscoTestAutomation. I hope it helps!
Thanks, happy to hear that!
