github issue
gordonray661
Visitor
Hi there,
I am a newbie for Cisco automation. I got an issue here:
remote: Repository not found.
fatal: repository ‘https://github.com/username/repo.git/’ not found
I just used the git clone the repository to my local directory but I can’t login my account.
I copied the token and pasted on macos terminal, but it seems not right.
Can anyone give an idea?
Alexander Stevenson
Hi @gordonray661,
Welcome. If you clone from the GitHub repo webpage, make sure you're logged-in first. Then, I like to Fork the repo:
After that, click 'Code' and then the 'Copy' button next to the URL.
Finally, you can go to your local directory and use 'git clone' plus the URL you just copied inside your environment.
If you have any more questions, just reply here and I'll help. If I don't respond it means I didn't see it, so message me through here please.
Best,
       Alex S.
