Guestshell not running
ArtukSi09230
Community Member
#guestshell enable
Interface will be selected if configured in app-hosting
Please wait for completion
The process for the command is not responding or is otherwise unavailable
#show iox
Virtual Service Global State and Virtualization Limits:
Infrastructure version : 1.7
Total virtual services installed : 0
Total virtual services activated : 0
Machine types supported : LXC
Machine types disabled : KVM
Maximum VCPUs per virtual service : 1
Resource virtualization limits:
Name Quota Committed Available
system CPU (%) 75 0 75
memory (MB) 3072 0 3072
bootflash (MB) 20000 0 6716
IOx Infrastructure Summary:
IOx service (CAF) : Not Running
IOx service (HA) : Not Running
IOx service (IOxman) : Not Running
Libvirtd : Running
2 Accepted Solutions
omz
conf t
iox
app-hosting appid guestshell
 vnic management guest-interface 0
end
wr
omz
you might have to wait a little a bit for IOx Infrastructure Summary: to show Running services
show app-hosting list
omz
conf t
iox
end
wr
Im also facing the same issue.
but unable to run the vnic management guest-interface 0 command
815(config)#iox
815(config)#app-hosting appid guestshell
815(config-app-hosting)# vnic management guest-interface 0
% Invalid input detected at '^' marker.
815(config-app-hosting)#?
app-default-gateway Application default-gateway
app-default-ipv6-gateway Application default-ipv6-gateway
app-device Application device information
app-resource Application resources
app-vnic Virtual Network Interface
default Set a command to its defaults
exit Exit sub-mode
name-server0 Name server IP Address
name-server1 Name server IP Address
name-server2 Name server IP Address
name-server3 Name server IP Address
name-server4 Name server IP Address Mgmt
no Negate a command or set its defaults
start Activate and Start/Run the Application
omz
