Meraki API Access Point Power Source
choywy
Like to know is there an API for Meraki that allows me to pull the Power Source of an access point? Currently in the GUI dashboard, there is a "Power" field that say "AC adapter" or "POE 802.3au". Is there an equivalent for that in the API?
omz
Don't think it's available via API .. https://developer.cisco.com/meraki/api/
Thanks...Are they planning to create one for the next enhancement? It is useful to check which one is using AC or PoE...Unable to click thru' the GUI for hundreds of them...
agree .. it would help to get via API..  might be worth making the feature request via Make a Wish button on Meraki dashboard.
Konad
Hi actualy there are
Get Organization Wireless Devices Ethernet Statuses - Meraki Dashboard API v1 - Cisco Meraki Developer Hub
and it returns to you if it is powered by "ac" or "PoE"
I hope that after 4 years it will be enough to solve the problem.
Greetings!
