problem filtering ClientDetails by macAddress
Team, why is filtering by macAddress not working for me below? This is with PI 3.0
[nbrunsga@localhost ~]$ curl -k -u user:password  "https://10.195.136.101/webacs/api/v2/data/ClientDetails?macAddress=64:76:ba:e9:05:2b"
<?xml version="1.0" ?>
<errorDocument>
  <httpResponseCode>400</httpResponseCode>
  <httpMethod>GET</httpMethod>
  <message>Bad or missing filter property value [64:76:ba:e9:05:2b] for property [macAddress] on entity [ClientDetailsV2].-PRS-113</message>
  <id>presentation.PRS-113</id>
  <uriPath>data/ClientDetails</uriPath>
  <queryParams>{macAddress=[64:76:ba:e9:05:2b]}</queryParams>
</errorDocument>
[nbrunsga@localhost ~]$ curl -k -u user:password  "https://10.195.136.101/webacs/api/v2/data/ClientDetails?ipAddress=10.194.205.176"
<queryResponse type="ClientDetails" rootUrl="https://10.195.136.101/webacs/api/v2/data" requestUrl="https://10.195.136.101/webacs/api/v2/data/ClientDetails?ipAddress=10.194.205.176" responseType="listEntityIds" count="1" first="0" last="0">
  <entityId url="https://10.195.136.101/webacs/api/v2/data/ClientDetails/940401" type="ClientDetails">940401</entityId>
</queryResponse>[nbrunsga@localhost ~]$
[nbrunsga@localhost ~]$ curl -k -u user:password  "https://10.195.136.101/webacs/api/v2/data/ClientDetails/940401"
<queryResponse type="ClientDetails" rootUrl="https://10.195.136.101/webacs/api/v2/data" requestUrl="https://10.195.136.101/webacs/api/v2/data/ClientDetails/940401" responseType="getEntity">
  <entity url="https://10.195.136.101/webacs/api/v2/data/ClientDetails/940401" type="ClientDetails" dtoType="clientDetailsDTO">
    <clientDetailsDTO id="940401" displayName="940401">
      <apIpAddress>
        <address>10.129.16.78</address>
      </apIpAddress>
      <apMacAddress>70:10:5c:1e:db:20</apMacAddress>
      <apName>Boulder-2</apName>
      <apSlotId>1</apSlotId>
      <associationTime>1448963525780</associationTime>
      <authenticationAlgorithm>OPENSYSTEM</authenticationAlgorithm>
      <ccxFSVersion>V1</ccxFSVersion>
      <ccxLSVersion>V1</ccxLSVersion>
      <ccxMSVersion>V1</ccxMSVersion>
      <ccxVSVersion>V1</ccxVSVersion>
      <ccxVersion>UNSUPPORTED</ccxVersion>
      <clientAaaOverrideAclApplied>NA</clientAaaOverrideAclApplied>
      <clientAclApplied>NA</clientAclApplied>
      <clientApMode>UNKNOWN</clientApMode>
      <clientInterface>svmdata</clientInterface>
      <connectionType>LIGHTWEIGHTWIRELESS</connectionType>
      <deviceIpAddress>
        <address>10.194.205.53</address>
      </deviceIpAddress>
      <deviceName>sjc29-wlc2-bottom</deviceName>
      <deviceType>none</deviceType>
      <eapType>PEAP</eapType>
      <encryptionCypher>CCMPAES</encryptionCypher>
      <firstSeenTime>1448373076952</firstSeenTime>
      <hreapLocallyAuthenticated>2</hreapLocallyAuthenticated>
      <ifIndex>0</ifIndex>
      <ipAddress>
        <address>10.194.205.176</address>
      </ipAddress>
      <ipType>IPV4</ipType>
      <location>System Campus &gt; Cisco Boulder &gt; Floor2</location>
      <macAddress>64:76:ba:e9:05:2b</macAddress>
      <mobilityStatus>LOCAL</mobilityStatus>
      <nacState>ACCESS</nacState>
      <policyType>WPA2</policyType>
      <policyTypeStatus>NOMETHOD</policyTypeStatus>
      <postureStatus>UNKNOWN</postureStatus>
      <protocol>DOT11N5GHZ</protocol>
      <securityPolicyStatus>PASSED</securityPolicyStatus>
      <speed>UNKNOWN</speed>
      <ssid>Boulder</ssid>
      <status>ASSOCIATED</status>
      <updateTime>1448963525983</updateTime>
      <userName>nbrunsga</userName>
      <vendor>Apple</vendor>
      <vlan>201</vlan>
      <webSecurity>DISABLED</webSecurity>
      <wepState>ENABLED</wepState>
      <wgbMacAddress>00:00:00:00:00:00</wgbMacAddress>
      <wgbStatus>REGULARCLIENT</wgbStatus>
      <wiredClientType>NA</wiredClientType>
    </clientDetailsDTO>
  </entity>
</queryResponse>
Message was edited by: Spencer Zier
Spencer Zier
Wrap the mac address in double quotes.  So instead of macAddress=64:76:ba:e9:05:2b you should have macAddress="64:76:ba:e9:05:2b" and since you're using cURL you'll want to escape the quotes, so macAddress=\"64:76:ba:e9:05:2b\"
Also, I edited your post to remove the username and password from your examples.  Be sure to change your password just in case.
Jean Matthew
Visitor
you could also try surrounding the mac address with %22
