Problems l2switch
fellas007
Community Member
Hello, I am developing an application with the feature l2switch to send packages by different paths, I already make the rules for sending the packages but Opendaylight does not send them. I have researched the feature that does not allow it to be loopremover, this feature puts the ports in forwarding or discarding. I would like to know if there is a way to send these packages using rules that I develop.
eckelcu
Hi Fernando,
I see you emailed the L2switch-dev list and received some troubleshooting suggestions. Did that help?
In general, there is no longer much development around l2switch; rather, the focus on netvirt.
https://wiki.opendaylight.org/view/NetVirt
You might want to consider developing on top of it instead.
Cheers,
Charles
