pyATS Schema Question : NXOS Parser
SteveNelson29701
Community Member
Hi Guys
I am hoping someone may be able to help with a basic pyATS query surrounding an NXOS parser.
I am using the parser for the command 'show ip interface vrf <vrf_name>' and capturing this within my python script to a variable.
I can see in the schema the following at the head :
{ Any (str) *: { 'vrf': <class 'str'>, 'interface_status': <class 'str'>, 'iod': <class 'int'>,
When I run the parser the the variable is populated with the relevant output, however what I would like to do is look up the status for all vLANS. I am using the following code snippet :
pre_status = pre_output ['VlanXXX']['interface_status']
However the above requires that I define the Vlan ID within the command.
Is there a way to use a wildcard initially and capture all of the statuses for the output ?
Steve
SteveNelson29701
Community Member
I resolved this issue, no resposnses required
Steve
